"hmm, I don't think that was supposed to happen"
CO
Ok so I was running my mt5 for about 20 minutes( the longest I've had time to run it yet), just having a good ole time when it started to whine a bit. I figured it was just the cold diff (4 deg outside) making the noise so I kept running when all of a sudden it stopped......no drive line action.
I started to think what could have gone wrong, I mean I'm not even through my first gallon of gas, the thoughts that I was thinking all had big $ signs around them too. And worse how was I going to explain to my wife that my new 1500.00$ "toy" was broke already.
Well I had finally gotten over to my immobile truck and what"s that I see on the ground? A spur gear? Well that's not supposed to be there, that's supposed to be on the truck!
.14 cents later with a new "E" clip from Ace Hardware I'm up and running again.
What are the chances that the E clip was never on the shaft in the first place?
What are the chances that it was there and it simply fell of?
What are the chances that it will happen again?
But most importantly..........What are the chances that my wife will find out???
RE: "hmm, I don't think that was supposed to happen"
atleast you found the spur gear!!!!!!! usually when something parts company on my cars its goodbye for ever...And as far as the wife let her find out dont be scared....lol
CO
She's not as bad as I made it sound, it just adds a bit of humor to what could have been a a very bad situation, broken car and using money to repair insted of hop-ups.
WA
the e clip probably wasnt on all the way or it was a bad one..... I use a metal spur the only thing holding it on are the grub screws
lucky you, when someing goes wrong 4 mr im never that luvkey, heres a good example of my current problems [link=http://http://support.nomadio.net/viewtopic.php?t=265]here[/link] yes im going to drop them in it becuse they have some very serious problems with the product i could have done so many things with 390 quid
CO
I will be switching to the steel gears after Christmas along with cable brakes, alloy diff, pre-filter, Jetpro pipe, silencer, and a ported 603 carb. I sure am glad that I can spend my cash on those items and not repair items.
P113 link is : http://support.nomadio.net/viewtopic.php?t=265
got messed up..
this things allways happen with RTR stuff.. more or less allways:P something will be kind half finnish or half off.. allways good to check every part of the truck
once you have run it and found out those really weak spots everything should be better:P
by the way P113... V2 of the sensor is just a software if im not totaly wrong
im 99% sure
got messed up..
im 99% sure
CO
Actually the first day of running I lost both of the steering stoppers (the long silver bolt things attached to the front a-arms). I looked for about a half of an hour in the snow and found both of them.
For some strange reason I felt like checking them today and guess what.... yep they were both loose again. I drilled a small hole at each end of them and ran a piece of wire to tie the ends together. No way they can come of again.
ORIGINAL: HeatFire
got messed up..
im 99% sure
got messed up..
im 99% sure
Its very annoying for something ive spent so much money it wont even work after over 2 weeks over messing around with it a buying new servos.
think you see my frustration.
WA
You can also check the general tightness of all of the of nots bolts and screws
It a good habit to form, before you go and play for the day
RTR check is mostly:
1. check all screws that they sit as they should
2. metal to metal screws = locktite
3. e-clips sit right
well in short atleast
lol you really gonna get a rocketship after those upgrades you should buy a hmm a ported engine 6hp but like 800$
