RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Robbe Battery failsafe
Old 12-29-2005, 07:11 AM
Mad Wax
Mad Wax's Avatar
Default Robbe Battery failsafe
Anyone use one of these? Looks useful if the main pack packs it'll go back to secondary pack (a AAA 4.8V should do)
http://www.rc-car-online.de/failsafe_eng.htm#3
Old 12-29-2005, 09:42 AM
chevyman_de
chevyman_de's Avatar
Default RE: Robbe Battery failsafe
I don't think a 4-cell AAA pack is a good idea. AAA cells are not exactly up to the loads of the high power servos in a largescale car. If you have only four cells that could easily cause a low-batt failsafe to engage. I'd definitely opt for a 5-cell backup pack.
Old 12-29-2005, 03:22 PM
chowderhead72
I agree with Chevyman although if you were to use a nitro type reciever pack (1200-1500mah) you might have something btw AAA's are only 700mah and not much better than nothing.
Old 12-29-2005, 03:59 PM
Mad Wax
Mad Wax's Avatar
Only for emergency failsafe though, surely it's enough?
Old 12-30-2005, 06:40 AM
chevyman_de
Even when it's an emergency, they're are still the same servos under the same loads. Some digital servos need 6 volts to run properly.
Old 12-30-2005, 06:47 AM
Mad Wax
Mad Wax's Avatar
What about when using analogue servos? (Hitec 645)
Old 12-30-2005, 07:28 AM
badz
badz's Avatar
One 1/4 scale servo will drain them 4aaa's in no time flat...toss a 5cell hump pack in it from a nitro or just run dual sub c packs....added weight wont mean much unless your racing....
Old 12-30-2005, 07:51 AM
chevyman_de
Four cells should be OK, but I would stay away from those tiny AAA cells and use AA cells instead.
Old 12-30-2005, 09:02 AM
Transporter67
Why not just use a normal signal and voltage failsafe and have a spare battery pack?
In case of total failure of the battery pack I have a 6v relay connected to the kill switch that shuts the engine down if the battery pack fails or becomes disconected.
