HELP!
HELP!
Help,I have just brought a 1/5th Bergonzoni of Ebay,and I have no idea of the startup procedure,or what sort of oiletrol mix,or if i need to prime it first.
any advice would be greatly appreiceated.
RE: HELP!
any good 2 stroke oil like castrol a747,king cobra venom oil or a good quality fully synth from a car shop - you can mix between 150 - 200ml of oil per 5ltrs of unleaded - to start just press the primer bulb on carb 2 times and pull the handle.
RE: HELP!
Be consistant with your oil mix, get a good AIR-COOLED motorcycle 2 stroke oil.
Press primer bulb until 3/4 full, choke on, one or two pulls, choke off, pull away until it starts.
