stock battery
RE: stock battery
The battery will have no problem; however the servo will only recieve the 6 volts that the battery can provide so you will have a bit les torque and speed from the servo.
RE: stock battery
The ampacity is not the problem it is the voltage. The 3300 will be fine as well but the speed and torque will be reduced. Do you have a link for this servo? Are you considering the new hitec robot servo?
Banned
RE: stock battery
Most servos and receivers will only handle 6 volts max. You can use a 7.2 volt pack but you will have to put a voltage regulator in to reduce the volt to 6 volts. Their are servos that can handle more volts 6+12 volts but those are special application servos ans they are expensive.
RE: stock battery
Banned
RE: stock battery
I Guess you want to use the HRS 5995 tg robot servo. I would suggest not. You will need the programmer to limit the travel of the servo and a radio with EPA set to 0. This servo is designed for special applications only. If you want more torque then I would use the hs 805 or the hs5745 servo or any other 1/4 scale specific servo. The other tg servos are for 1/8 scale.
