Tuning
Tuning
im hoping to finally get around to tuning my engine tommoz, Im guessing its the needle that has a H stamped nxt to it as the other one has an L :-) ? when i go over 3/4 throttle its holding back a little, any tips much appreciated when i tune it :-) ?
RE: Tuning
Tell me about your motor:
Does it hessitate always (hot or cold)
How many hours on the engine?
Remove the plug; what does it look like? (color,condition)
What fuel?
What oil?
Condition of air filter?
What air filter?
any recent changes? (gearing,fuel,etc)
Gear mesh issues? (long shot but cover all the bases)
What fuel?
What oil?
What air filter?
RE: Tuning
hi there :-)
Does it hessitate always (hot or cold) - Only when above 3/4 throttle, it just seems to hold back..its when engine is hot as ive only tried when after running it for over 20+ mins
How many hours on the engine? about 4+ tanks.. last tank lasted over 1 hour!
Remove the plug; what does it look like? (color,condition) ..looks in clean/good condition
What fuel? unleaded ?
What oil? castrol a747 - 25/1 mixture
Condition of air filter? very good condition, cleaned it & re-lubricated it if it gets mucky
What air filter? not sure of name, its one that come with FG MB pro (not the normal MB) i was told the one that comes on the pro is a good one so i left it at that
any recent changes? (gearing,fuel,etc) no changes
Gear mesh issues? (long shot but cover all the bases) gear mesh seems fine, ive been keeping a close eye on it, early on there seemed to be a prob, but ive sorted that & checked all meshing etc & seems fine
It seems to do with the tuning as i can hear the sound of the exhause change when i go over 3/4 throttle, as if theres not enuff fuel going through, or too much?
engine is the Zen g260, thanks for help :-)
RE: Tuning
When you say the plug looks fine what do you mean? Your high needle could be a litle lean or a little rich but the plug will tell which one it is. If the plug is vry clean with some ash you are too lean, if the plug is a little black and gummy you are too rich. Try running the motor full range with after only two minutes of warm up. (still cold) Any improvement? If it runs worse you are too rich, If it runs better you are too lean and the motor is getting hot and leaning out further.
Have you tried stock settings?
You said unleaded gas? What octane? Racing gas?
RE: Tuning
contact simon at www.sbracing.co.uk he spealizes in tuning these babies and has good knowledge of them
hope this helps
hope this helps
RE: Tuning
ty guys :-)
atm its at stock settings, ive never touched the settings yet :-)
all i know is the fuel i use is the unleaded fuel from a normal petrol station, no fancy stuff etc :-)
