tyre removal
tyre removal
what is best method for removing tyre need to remove tyres off my 1/6 xlb buggy transfer to other rims all help appreciated.
RE: tyre removal
Hi J_D I know what you mean have tried before and ripped tyreS.wHAT IT IS TWO RIMS ON MY XLB ARE DAMAGED DOWN TO ME NOT CHECKING WHEEL NUTS TO BE HONEST BUT TYRE ARE BRAND NEW AND HAVE TWO NEW RIMS SO WILL HAVE TO AT LEAST TRY TNX ANYWAY.
RE: tyre removal
I use super glue/CA debonder or release.
Let it stand for a day or so making sure that it doesn't dry out (where the glue join is) and the tyres can be gently removed from the rims.
I had to remove a FG monster tyre from a broken rim and it worked fine for that.
RE: tyre removal
if u use the nail polish remover DONT USE STRAIGHT ACETONE like u buy from the paint store it will eat the rubber leaving the bead still on the rim also i have used a heat gun i have tried all the methods and they all work about the same
