Types of plugs???
MN
Types of plugs???
Can anyone tell me there opinion if one spark plug is better then another? I read that the Champion stock plug goes bad now and then but, is there a better plug that can give better performance or should I stay with the Champion plug? Could you also add the # or Type of plug if not Champion - Eg. CHamp RZ7C. for 26CC
Thank you!
Thank you!
RE: Types of plugs???
i
thats the type of plug that i have in my monster beetle pro
very new to this game but had nitro for years them glow plugs
the only reason god invented them was to p**s man off.
question how often do you change / check the plug in these things.
john
john
There is also the Iridium version of the NGK CMR7 or CMR8. You can get the stock CMR7H or the CMRHIX over at
http://www.davesmotors.com
Use discount code 'RCU'
Ken
Ken
MN
I just picked up the NGK CMR7H. How did you hear of this plug working in the 260? I tried doing a cross ref on the champ to look for higher grade but got nothing. NGK looks allot like the Champ but as I know from using them elsewhere they are a more reliable plug. There is no worry of engine damage is there? Thanks again...
UT
If you have a look at the Zenoah manual for your engine:
http://zenoah.net/products/hobby/dow...G260RC_307.pdf
You'll see the NGK CMR6H and CMR7H listed as 'optional'... which means a whole lot of NGK plugs, including the CR8HIX, work great.
MN
Thanks for the link! I can read that! I only received 1 sheet of paper on the motor when purchasing my MT and most of it is in broken English and the rest I believe in German.
Thanks for all the help
