gear ratio formula
ME
gear ratio formula
Anyone know the formula to figure out the final gear ratios?
For example: with a 16/48 pinion/spur and 15/48 layshaft/diff gear the final gear ratio is 9.60.
I have 16/50 pinion spur with a 15/48 layshaft/diff and am trying to figure out what my final gear ratio would be.
I also want to know the formula so if I want to put say a 17/48 layshaft/diff with 16/50 pinion spur...what would the gear ratio be.
amitysanimal
amitysanimal
FL
RE: gear ratio formula
You take the gear ratios separately as division... 48/16=3.0/1 ; 48/15= 3.2/1
Then multiply the results...... 3.0x3.2=9.6/1
so...
50/16=3.125/1
48/15=3.2/1
3.125x3.2=10.0/1
and...
48/17=2.824/1
50/16=3.125/1
2.824x3.125=8.825/1
Enough of the math lesson... Gearing up for any paticular reason?
so...
50/16=3.125/1
48/15=3.2/1
3.125x3.2=10.0/1
and...
48/17=2.824/1
50/16=3.125/1
2.824x3.125=8.825/1
ME
Thanks alot, I really appreciate your help.
I have 3 sets of tires, I have the MB tires, Marder tires and the CNR 40 series alloy rims with Moabs. When you switch to the Marder tires, I need to gear up quite a bit. I also want a set of on-road tires and would need to gear up.
I have the stell gear conversion using 16/50 so some of my gear changing will be done with the layshaft gear.
Thanks again,
amitysanimal
Thanks again,
amitysanimal
WA
Hi I have a gear ratio and topend calculator on ebay.co.uk - it will work out ratios and top speed with those gears/trye size/RPM
http://cgi.ebay.co.uk/GEAR-RATIO-CAL...QQcmdZViewItem
