hitec servo question?
MN
Help
I just ran my MT wide open throttle over the snow bank and into the ditch! Why did you do that my son asked? Well because my hitec HS-5645MG digital ultra torque servo just stopped working for approx 15 sec. I investigated it a while and found that the servo is failing every so often and for different amounts of time. It's just loosing power. I checked all the connections and battery power and all is fine. The stering servo has no problems thank the lord because at least I was able to control the caos which developed. Is the servo trashed? Is this common with this type of servo?
I'm installing the Z590 Hi-Torque servo I got with my Spektrum DX3 right now to replace it. Is there a better servo to run for your throttle/brake.
RE: hitec servo question?
it seems a few people have problems with that particular hi-tec servo but usualy burning out, what you mention seems to be caused by loss of siginal which *might* be summit to do with your receiver?
MN
I thought the same thing but the radio and receiver are new and it seems to only do it only with this servo not the steering servo. I looked at the back of the radio and the receiver and both green lights stay lit and the steering still goes so I don't think siginal loss is the prob. I will be testing the new servo for any prob today. Just thought mabey there was something with this digital servo that starts to cause it to fail like this.
Thanks..
Thanks..
MN
Well it happened I changed out the servo and all was well. I rechecked the hitec and it started doing it again and now has stopped for good - Guess it was slooowly burning out if thats possible RIP. Time to go get a better servo!
ORIGINAL: hellya
I use 2 Hitech 645s for the steering and brakes.... 805BB for steering no problems so far
MN
WOW! Sent in the servo to Hitec to see what could be done - They fixed it and sent it back!!! Said they found a cold solder or loose wire. I did'nt think service was around like that anymore. That sure makes me think twice when ordering my next one. Another satisfied customer.
