reed block conversion???
ok brain boxes....
can you lot try to explain exactly how a reed block conversion adds power please.
ive replaced reeds and reed blocks on crossers in the past but never fitted them as a mod.
just cant see how it works. i am assuming it has to be in conjunction with porting but cant see how they work in conjunction.
any explanations gratefully received.
regards,
paul.
regards,
paul.
RE: reed block conversion???
ok brain boxes....
regards,
paul.
regards,
paul.
yeh but how much does all that cost? 4 bolts and nice mods sounds expensive. looked at oddified motors and theyre bigĀ£Ā£.
WI
too bad we can't have it all, reedvalves and flatslides,now wouldn't that be the cats *****, no more butterflyvalves[:'(], these engines are too small for these types of upgrades I would think
UT
Reed Valves add more power throughout the entire RPM range of the engine, this is why Motocross bikes utilize them. They are no longer the simple carburated setups so the engine more efficiently gains power. Any Reed Valved engine will out perform a purely carburated one and will reach higher RPM's than simple carburated engines.
CA
ORIGINAL: carpy100
That oddified dude is crazy!! he sells an engine with just porting for $500+
Even stock engines they sell for a lot...
So you have to look another direction...in goped world
