Need Help with oil and gas mixture
NJ
Hey all... I just got my fg mt in today and I am so eager to run it!!! However, I do not want to mess the engine up so could anyone tell me whats a good ratio for the first couple of tanks... and also with that ratio how much oil to a gallon of gas... pics and vids are coming soon
RE: Need Help with oil and gas mixture
200ml-5L gas.
Run it for 10 mins nice and easy then let it cool down for 15 mins.
repeat till tanks empty.
refill and start using full throttle.
I'll be the first to say American units are a pain. 1 gallon = 128 ounces.
Assuming I'm doing this correctly:
20:1 = (20/1) = (128/x) x = 6.40 ounces added per gallon of gas
25:1 = (25/1) = (128/x) x = 5.12 ounces added per gallon of gas
30:1 = (30/1) = (128/x) x = 4.27 ounces added per gallon of gas
40:1 = (40/1) = (128/x) x = 3.20 ounces added per gallon of gas
Feel free to correct me if I'm wrong, but I think that's the deal
For running in use 25:1....I did this for 2 tanks then went to 35:1
50:1 is too lean....I think 35:1 to 40:1 is best.
I just start with 100ml of oil in my container then decide on my ratio and add that amount in fuel ...eg 35:1 add 3500ml.
WA
These guys aren't from the states with their mililiters and litre of fuels
I add 4 ounces of 2 cycle per gallon of gas................ never had a problem yet
FL
ORIGINAL: hellya
for those who don't know that is a 32:1 mix (128oz per gallon) Standard 2-cycle lawn equipment ratio
50:1 is fine,
In the US we can buy a ratio cup, usually made by ratio rite( check with motocross guys) then you just fill to the oil line for the amount of fuel you have. usually they have 25:1, 40:1 and 50:1 on the same container.
ON, CANADA
Check out this thread. I've posted pics of something you can get a any Walmart which will help.
http://www.rcuniverse.com/forum/m_37...tm.htm#3728156
ORIGINAL: hellya
