Alcohol Engine
Alcohol Engine
Is there anyone out there running there cars/trucks on alcohol? I am planning on getting a Baja 5b when I get back from Kuwait and want to run it on alcohol. What am looking for is a small round slide mikuni carb and fuel pump to replace the stock unit. Appreciate any info.
RE: Alcohol Engine
ORIGINAL: ryan@ddm
Yep, all you need is a WT-499 carburetor and your Zenoah or Chung Yang engine will rune fine on alcohol.
UT
RE: Alcohol Engine
Meters appropriately (the volume of alcohol-based fuel needed is MUCH larger), has internal components which won't be damaged by alcohol, etc.
http://www.davesmotors.com/store/product869.html
RE: Alcohol Engine
thats interesting, i assumed you needed less fuel.so what are the realistic gains using alcohol?what ignition changes?spark plug etc.pro's and cons.....?
RE: Alcohol Engine
UT
RE: Alcohol Engine
A very useful primer on fuels can be found here:
http://journeytoforever.org/biofuel_...manual1-2.html
RE: Alcohol Engine
mate did this on marine engine
coil pack removed
glow plug machined to fit with spacer ring
mad no diffrence to top speed or power what so ever
just increased fuel costs
coil pack removed
RE: Alcohol Engine
just looking at the wt 499 carb wont this cause problems as it dosent seem to be self priming or it dosent have the priming bubble
RE: Alcohol Engine
i bit of a faf for somone like me takin the filter on and off all the time, would it improve performance on gas because of the smoother bore and also could a priming bubble be fitted from a old carb?
