F1. RIMS AND TYRES???
what do you need if anything, to convert a marder race to take F1 rims and tyres?are the squares the same etc,if not how do you modify?
all help greatly appreciated.
regards,
paul.
regards,
paul.
RE: F1. RIMS AND TYRES???
excellent news, thank you has anybody got a link to buy some? ive been looking about but cant find any. doesnt appear to be any on ebay?
regards,
paul.
regards,
paul.
OK,found wheels and tyres.saw a post with a picture of a marder wearing F1 rims,cant find it.wanting to find it to see wether you use F1 rears for front and back on the marders?does anybody remember or know what is the best set-up?
thanks again.
regards,
paul.
thanks again.
regards,
paul.
MN
we use f1 fronts on the front and rears on the rears. the f1 tires work better due to there size being closer to the stock marder tires.
Larger,wider,stickier... The F1 tires are almost the same diameter as the off-road buggy tires so no need to change gearing.
Carpy: It is standard practice to run F1 rears on the rear and F1 fronts on the front. Those F1 rears look huge don't they?
thanks for replies lads,looks like buckets of fun and total mayhem.
do the compounds make a lot of difference or is it negligible?
for some reason i can find pre-glued rears but not fronts??
http://www.rapid-racing.co.uk/produc...ubSubCatName=&
ORIGINAL: mnf1sand
the best is the GRP A compund rear and B compound front. They do not come mounted.
MN
A is the softest then B and C etc... with the PMT's the lower the number the softer, so its 05, 10, 20..etc.. The GRP last much longer, they both grip about the same. The problem that you will have chowder will be the on-throttle vs. off-throttle traction. if you put a soft front to turn when on-throttle you will have a car that will have way too much turn on the brakes. I would work with suspension, more rear spring preload, less front droop. that sort of thing.
