Engine issue
ON, CANADA
Engine issue
Just ran the Leopard Race again today and it wasn't running as good as before. [:@] The only thing I did different was add gas to it with a new mixture. If I had more oil in the mixture would it bog down mid range to high ?? Just wondering if I should add more gas to the tank and see. I use around 30:1. The engine is 3 years old and ran fine on Sunday. Idles fine too. I started to play with the H and L settings from stock 1.25 and 1.25 but still nothing changed much. It's a Zenoah 230RC1
Any Ideas??
Any Ideas??
RE: Engine issue
Sounds like you may have sucked some dirt into the carb on Sunday and now you have lost alot of compression. Look inside the carb for remnants of sunday's fun. Could also be a very dirty air filter or crap in the carb jets.
ON, CANADA
RE: Engine issue
I'll take a look at the carb. I have an air filter cover over it so it shouldn't have. I use the same one on the Marder and hardly have to clean it. Plus I was running on grass too. Anything is worth a look too. Maybe I may have mixed it too rich, if so wouldn't I have a lot more smoke though?
