Any Suggestions on problem getting shock allen screw out
I put alloy Front Arms On My marder during the last summer. i also cracked up the front end during the summer. the arms look okay just looks like one of the steering stops bent alittle. my problem is when i put the arms on i used medium loctite on the allen screw for the shock on the bottom arm. i tried heating the arm up but i cannot get it to come out. i think now i have round the allen wrench socket. Any suggestions on how to get the screw out? Will a screw extractor work? Do they Make them that small.
Thanks Shymot
Thanks Shymot
CA
RE: Any Suggestions on problem getting shock allen screw out
Can you post a pic? We have helped others on this board with machine work. We may be able to help you out.
Tony
R/C Modelsport
Tony
R/C Modelsport
try putting some nail varnish remover on lett it soak in and around the threads, did this with a bolt snapped in the engine mount and it removed it, nail varnish removes super glue ect.... works also great on rimms and tyres
Put a soldering iron on the screw itself rather than the arm
If you have rounded the head try a torx bit, it may just grip it enough to remove.
put some valve grinding compound in the rounded hole and and try it again this stuff takes up the xtra space and bites into the screw
Thanks for your Suggestions. I Used One of those sears micro mini easy outs and it came right out. This was after i cut off the bottom of The shock and tried using a pair of pliers.
Thanks Once Again
Shymot
Thanks Once Again
Shymot
