Convert Marder or Beetle to Stadium Truck
Are you looking for a change to your Marder or Beetle? Complete kit available now to do this conversion.
ON, CANADA
RE: Convert Marder or Beetle to Stadium Truck
just buy a body, wheels and tires and 16/44 gearing and you are done
by the way, thoses wheels and tires doesnt look as nice as the fg ones
The correct gearing for the Marder, Beetle and Stadium Truck is actually 18/46. 16/44 will not work together. The tires shown are the PMT tires mounted to the Marder Race wheels, so if you already have the wheels, then you only need tires. Or you can mount the actual Stadium Truck tires and wheels. You do need a few more parts than just the body to install onto the Marder or Beetle.
what else do you need? i would love to make my marder buggy an ST (just body and big foot wheels if poss but i think it needs engine mounts too?)
CT
ORIGINAL: FG Perf RC
What bodyposts do you need for the front? And how would you mount the rear if you didn't want to use the rear wing?
Cheers
Cheers
you may need the FG rear cage, or you may be able to mount the ST side posts on the current hammer cage. front posts are FG part number 7154 mounted in the stock tower , hammer may need some adjustment, look at the diagram of the FG Monster Beetle and see if a simlar mount may work.
CT
MN
These are the parts you would need to make the conversion.
2 x 7154
1x 6106
2x 8466
1x 7011/01
1x 6716/22
1x 6175
1x 6176
1x 6729/20
1x MMR6192
2 x 7154
1x 6106
2x 8466
1x 7011/01
1x 6716/22
1x 6175
1x 6176
1x 6729/20
1x MMR6192
