pinion gears
pinion gears
does the 16t steel diff/idle gear (6431) on a marder race have the same teeth profile as the 16t steel pinions used on mt - are the both the same gears!!
RE: pinion gears
ORIGINAL: carpy100
the narrow one is for the layshaft.
On the clutch bell you should use the wide one in combination with plastic spur gears. If you use a steel spur gear, you can use both versions.
RE: pinion gears
thanks - thats what i needed to know,i swapped the 16t idle gear for 14t for monster wheels,so saved a few ££ if i can use the 16t on the clutch bell as im using a steel spur.
