spak plug
RE: spak plug
The stock plug that Dave's Motors sells with the Zen G260 is the CR8HSA:
http://www.davesmotors.com/store/product289.html
The CMR7 plug came with my CY 23cc engine. Both will work.
The Iridium plug CR8HIX is taller than the stock CR8 and CMR7 plugs and make it more prone to breaking if you flip over. Iridium plugs fire better and should give you a small incremental bump in power. Probably not worth the hassle on a stock engine.
Banned
RE: spak plug
ORIGINAL: carpy100
there bloody not! champion are renown for breaking down. me my family and nates have all had probs with them.
Spark plugs are tested under more extreme conditions than the regular usage you are using them for. If you are having problems contact the mfg. and find out the problem. It's not the plug.
