shocks on the Baja
ON, CANADA
shocks on the Baja
Just wondering for those who have one, how are ther shocks on it? DO es it still bottom out or make the "whack" sounds after a jump? Others in the nitro world seem to think it depends on the oil and spring tension as well as the piston. I on the other hand have tried several different setups and still found under high jumps no matter what the c-clip inside fails and bends. If it's a threaded rod with aluminum pistons then there is no issues. PLus the weight of these machines do not make it easy!!
WHat are your thoughts/ experiences on this.
RE: shocks on the Baja
I was surprised to see that one Baja owner had a snapped piston rod when the wheel hit a goal post. They didn't mention what happened to the rear suspension arms or hinge pins. The shock bodies look nice.
