hopefully figured out my prob with trans
TX
i was running my fg st and then all of sudden i heard a rattling noise coming from the diff. and oh my god i thought i locked the diff up. I look at it was the brake hub hitting. the corners of the hub are round off. I installed the two speed and there is a little play in the lay shaft if you move it horizontal so tonight i will either get everything tight by pressing the hub in more or just file the corners of the hub down a little. Hopefully this is my prob
