Tire Balance Weight's
RE: Tire Balance Weight's
just use anything just make sure it has some mass [8D]
although you'll lose ur balance the second u go offroad and it fil with dirt. but hey, its up to you
OH
you should be able to get stick on wheel weights from any tire retailer, just make sure the wheel is very clean when you balance it and then cover the weight with a piece of duct tape so it doesnt fly off. The weights are normally 1/4 oz each but you could cut the in half or quarters with a dremel tool, you could even cut up a piece of 1 cent coin and tape it to the inside of the rim or use a bit of CA glue to hold it
i must be missing something but why would you want to weigh down your wheels? :s
isnt that illegal?
TX
[8D] I want to add weight ( Probably only a gram or so ) 1 gram = .001 kilogram. If I put my MT Bigfoot on a stand & roll the tire it has a heavy spot so if I balance the wheel's, & it should run smoother[sm=thumbup.gif] & maybe a little faster.[sm=lol.gif]
OH
Dont call the US mint just yet, i DIDN'T say cut up a penny, i just said a one cent coin. Where you get your currency is your business .
SD
I used a good double sided 3M foam tape and took some of my cheap fishing weights. I smashed the weights with a hammer to the shape I wanted, trimed them up with some wire cutters and stuck them on.
To figure out how much weight to add I used modeling clay to determine the proper spot and weight. I then weighed the clay with a postal scale and made the lead weights accordingly.
I used this method when I put the 23mm pro-line wheels and moab tires on my Fire-hammer. I ran in dirt, rock, grass, and never had a problem with them falling off or causing any other problems for that matter. They stayed balanced after the initial install.
Makes the buggy handle better, and dramatically reduced vibrations.
Electronjunk
Electronjunk
Banned
HG. go to a golfing store, get some golfers tape, its a led tape with adheasive backing, and the adheasive is strong... just what you need.
if it were a spa, youd get a happy ending before leaveing..lmao
Timmahh
Timmahh
CT
ORIGINAL: ScooterTrash
[sm=thumbup.gif] Thanks alot ElectronJunk, I sure do appreciate your input![sm=sunsmiley.gif]
TX
[>:] Nothing, I just think it is a cool engine! I am a machinist & thinking of all the precision work, it take's to make one! PS: If you don't like it, don't look at it!
CT
