RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Best 2 Stroke Oil
Reply
Old 08-01-2006, 12:11 PM
hndaman1
hndaman1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Best 2 Stroke Oil
I have been using the Honda Pro oil HP2 @ 25:1 mixture using 87 octane and my buggy rips(the 29cc kitted engine) and the same in the stocker as well (23cc CY engine)
hndaman1 is offline
Old 08-01-2006, 01:51 PM
Oneill Brothers Racing
Oneill Brothers Racing's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We've been runing castor 927 for awhile now and it seems to be a very clean burning oil.
[img]http://rds.yahoo.com/_ylt=A0Je5miFoc9EFesAclKjzbkF;_ylu=X3oDMTA4NDgyNWN 0BHNlYwNwcm9m/SIG=12gtjpabg/EXP=1154544389/**http%3a//www.parkeryamaha.com/ProductImages/lets/castor927.jpg[/img]
Oneill Brothers Racing is offline
Old 12-15-2007, 04:57 PM
Skippykix
My Feedback: (99)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I recently aquired a DA-100 in a AW Extra 260. The motor just finished break in on lawn boy 32:1. I called Jeff at Desert Aircraft and asked what oil to start running in this thing if he had Amsoil Saber 100:1. BelRay H1R 50:1 or RedLine Racing Oil 40:1 and he stated that he would use the RedLine Racing Oil.
Skippykix is offline
Old 12-15-2007, 10:47 PM
Cacique_2002
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Earth Surfer
How much oil a engine needs is pretty much dependent on the RPM a engine makes. The higher the RPM, the more oil it should have generally. Thats why Zen suggests 25:1 I am sure. I run 28:1 with Maxima Castor 927. I allways liked castor oils, but in the old days they could get pretty gummy (and actually gum a ring in a piston groove). But this oil is a castor/synthetic blend, and runs pretty clean with good jetting and fuel mix. This oil has a high flash point compared to a lot of other oils, and I think it can handle the heat a bit better than most. But that is just my opinion. Oil is a personal preference, and there are a lot of good oils out there. It seems, when you find a oil you like, you tend to stick with it.
Here is a neat little measuring cup that measures any ratio you want for 1, 1.5, 2, and I think 2.5 gallons. Liters may be on there too, I am not sure. I would not mix without it.
http://www.davesmotors.com/cgi-bin/s...9247fa14dd4780
I am also using the Maxima Castor 927 with 95 Octane unleaded fuel at 25:1 ratio on both my F1 Zenoha 26cc and EVO02 Zenoha 23cc. Everytime i run the car after a while (20 to 30 minutes) the engine shuts off by itself. I pull start over and over and the engine won't start. I remove the spark plug and it has a black coat around it and I test for sparks and nothing. Then i clean the spark plug with a metal brush to remove the black builtup and then put it back on the engine. Once the spark plug is cleaned then the engine starts. I am using too much oil or the wrong spark plugs??? Why do I have to clean the spark plug so often??? i am using NGK CH7
LRR
Cacique_2002 is offline
Old 12-15-2007, 11:24 PM
hathi
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like you may be running on the rich side and fouling up your plug. How is it running? Is it "4 stroking" at high rpms?
hathi is offline
Old 12-16-2007, 11:38 AM
  #31
Cacique_2002
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: hathi
What do you mean by "4 stroking" at high rpm??? i never heard that!
LRR
Old 12-18-2007, 01:35 AM
  #32
Hairballusmaximus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
4-stroking is where a2-stroke is rich enough that it actually fires on every other "up" stroke instead of every "up" stroke. ( up stroke=compression stroke)
Hairballusmaximus is offline
Old 12-18-2007, 04:02 AM
  #33
tom111
tom111's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am using Motul oil. It is 100% synthetic oil for 2 stroke engine and it is absolutely wonderful, it is used for racing by Subaru
http://www.motul.com/
This site sells them:
http://www.starcycle.com/street/motul.html
tom111 is offline
Old 06-22-2011, 06:03 PM
  #34
captinjohn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Red Line is one of the best 2 stroke oils now! June 2011....my how time flys@
captinjohn is offline
Old 06-22-2011, 08:25 PM
  #35
mooman007uk
mooman007uk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
belray H1R mixed at 32:1, 40 tanks now on my obr 27'2 full mod, one re ring at 30 tanks and still has all the machining lines on the piston, bore is immaculate..in other words the piston and cylinder look like new,bore and piston mic' d same as new also. good thing is belray changed the colour of the oil ,used to be piss yellow which was hard to see in the tank and also hard to tell if from regular gas out the can, now it's red so much easier to see in your tank and you know you're not chucking straight gas in it...after a few beers it's very handy, could never tell before if i'd mixed it or not, now i can see even if i've had a few
mooman007uk is offline
Old 06-24-2011, 12:05 PM
  #36
ejweelin92
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lucas from auto zone - works better then the amsoil domm i use to run
ejweelin92 is offline
Old 06-24-2011, 02:47 PM
  #37
speedypetey61
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You people are getting me sick, there is only (1) BEST oil you will ever use in your 2 stroke (modified) motors, KLOTZ BENOL.
END OF STORY.
I said I was not going to let the cat out of the bag, but your guys are so F'ed up about this whole thing, I just could not hold back.
I have been racing large scales for 15 years, I have used it all in all types of motors, it stops here...Happy Birthday guys.
Report back with your progress so we can set everyone straight.
For the record Amsoil is [:'(]
Castor 927 is also great stuff.
speedypetey61 is offline
Old 06-24-2011, 06:20 PM
  #38
devo208
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hear that that benol isn't good for these engines, i heard that what i'm using is best #1 oil for these engines and that the Honda Hp2. http://youtu.be/gT1ytbdBp4w
devo208 is offline
Old 06-25-2011, 12:42 PM
  #39
RC-NUKE
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Guys, I have an FG F1 w/ Zenoah (Komatsu) 28cc engine. I found a 2-year old bottle (1 quart) of Evolution blended oil with an additive called ZX-7.
I am not sure it would be safe to use it anymore as lubricant oils for 2-strokes are unstable and deteriorate over time. I notices what used to be teal color pigments
are absorbed by the plastic bottle, leaving the oil now clear and colorless.
I have used Klotz last year and liked it. But just wanted to get your advise before I threw out the Evolution oil.
RC-NUKE is offline
Old 06-25-2011, 02:02 PM
  #40
trickle007
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use same oil just 25:1
P.S. I have read once you go synthetic you must always use synthetic
ORIGINAL: mooman007uk
trickle007 is offline
Old 06-25-2019, 04:15 AM
  #41
hairy46
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default I use stil two stroke oil
32/1 and a ounce of Marvel mystery oil, per gallon, but I run av gas and it's a dryer fuel.
hairy46 is offline
