Reversing Servos?!
Reversing Servos?!
Hey,
Any of you guys know the easiest to reverse a servo? im currently running 2 servos off one channel and want to reverse ONE of them for my new cable discs? Can i do this with a special Y split? any idea where i would get one from?
cheers guys :-)
cheers guys :-)
TX
RE: Reversing Servos?!
[8D] You can get one here->[link]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXL307&P=ML[/link]. I don't know if you can or cannot reverse just one? Some one elce should be able to help you out. Good luck, PS: Look here also->[link]http://www.google.com/search?hl=en&ie=ISO-8859-1&q=reverse+a+servo%3F+im+currently+running+2+servos +off+one+channel+&btnG=Google+Search[/link]
ORIGINAL: strong_material
dont you have 3 channels on your radio? use the 3rd channel for the front brakes.
even if you have 3 channels, you need to be able to mix them so they operate at the same time.
My M8 has three channels but no channel mixing, so i needed a Y connector.
NJ
reckon! lol.
maybe its time to upgrade ur radio? because with channel mixing, u can change ur brake bias on ur radio, ie. give it a bit more front end breaking, or more rear end.. ect ect
