G23RC1 Engine Problem
MI
Hi i have a FG Monster Beetle Pro with a Zen G23RC1 engine with a JetPro Pipe and i was running it today and it was running fine for about 10 minutes and then it started to surge in RPM's it go from low to high i though it was my radio glitching but the throttle was closed and the servo was not moving then i went to the idle screw but that had no effect on it then i look to the low end screw first i leaned it and it just stall then i richen it and it then engine just raced faster I'm all out of ideals of what can cause this problem do you all think that i might have leak in the head gasket or the crab gasket or even a vacuum leak some where please any help with this all so the engine has only about a gallon of gas threw it
MI
RE: G23RC1 Engine Problem
Thanks for the fast reply Acs guitars that was fear i know air leaks are a pain to trace down but i guess ill have to try and locate the leak
will almost deffinitely be base gasket or maybe carb insulator drawing air. the latest batch of zen motors have been leaking on the base gaskets due to a slight mismatch in the crank case halves.i had to use hi temp loctite to seal mine properly.i've seen it on 4 new motors recently that have sufferd this on only one or two tanks run time.
MI
Carpy the base gasket that you are talking about is the gasket between the crank case and the head or jug and the carb insulator is the gasket on the carb right just checking your info thanks
FL
The insulator is the ported block between the carb and engine. I believe he is referring to the head gasket when saying the base gasket.... I could be wrong.
MI
OK i got it do i just start by replacing the gasket and the insulator on the carb first because the my fuel line and vacuum line seem to be fine so i don't think its leaking from there so my next thing to do is to pull the carb off and look at it is there a way i can check to see if it is leaking from the carb gasket or insulator with out pulling it all off
Banned
get it running, grab a can of starting fluid, lightly spray the gasket areas of the motor when running, you ll hear a change in RPMs if you hitting a leak with the starting fluid.
Timmahh
Timmahh
