FG 4x4
AB, CANADA
FG 4x4
So, im checking out this 4x4 Kit (Chain Driven one) for the FG (MT) and I am curious, what else you will need to buy. Does this kit come with everything you will need, then transfer the rest from your old MT? Or do you have to purchase other items?
Do the front Drive shafts come with for example?
Looking atthe pictures its tough to tell just whats included and whats not.
Also, for the price..1300$ is that gold plated?
I know there was some workings on a Belt driven one 4x4 kit that wasnt 'Gold Plated' is there any new word on them?
RE: FG 4x4
The belt one is the kamatiro one, it is out already sometime.
Micros used to post here comments he seemed to be close to the source of info on Kamatiro, but I haven't seen him here a long time, nor on the German forum.
Check at Hobbythek (rc-car-online.de) they should have them in stock and is about half the price of the chain one.
Plus on the belt one is that there are FG parts re-used, so with spares you should be fine.
How the belt holds up I dunno, but replacing the belt is a cheap thing (8 USD I gues if you look into a car shop).
I believe steering was also limited a bit due to the steering arms limited movement, but when you do not need to make tight corners that is a thing you would survive easily. There are not many posts on the german forum on the kamatiro set either but from what I did saw is that it seems to work fine in the dirt as well. On the dutch forum a guy posted some pics of his marder, his 4WD kamatiro project is now in progress so he did not write any reports on driving the 4WD system.
See some pics here:
http://www.gdesigns.nl/images/marder_4wd/18.jpg
http://www.gdesigns.nl/images/marder_4wd/15.jpg
Hope this helps
From what I heard through the RC-vine is that FG is still busy getting the 4WD project correct. It takes long but I bet once released we can enjoy a real 4WD Probably it won't be a conversion kit but a new car is my best gues.
Other than that you can try the MCD (spare parts is problematic) and WWS I saw having a prototype, unfortunately they did not drive it though.
But engine placement was not logical on the WWS to me and I would then go deffinately for the MCD technically seen. In the WWS proto the engine was placed sideways ->> this likely results in tilting the car to one side when accelerated.
Or go Nitro [:'(] and then you have plentuy of 4WD options.
Well that is not an option really, is it ...
See some pics here:
Hope this helps
MN
RE: FG 4x4
I thought of the same thing but you could probably buy a MCD for around the same price stick your motor and engine in it and have a brand new truck. Just a thought.
[link]http://cgi.ebay.com/1-5-Scale-4X4-MCD-Monster-Truck-FG-zenoah-baja_W0QQitemZ190027645805QQihZ009QQcategoryZ44029 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem[/link] - Not that this is the best price but it is close.
Oh and I think its shaft driven.
AB, CANADA
RE: FG 4x4
Ya, im torn between The FG kit, and the MCD, and of course the Kamatiro is a hot lookin truck, and mostly upgraded to. I guess my issues with the MCD, are that I already have alot of alum on my FG. And feel that I may have to beef up the MCD as well, but your right, I can swap engines, as well as electronice...the Kamatiro comes ready to go, with my own electronics, therefore giving me 2 RC's...kinda..lol
And whats Nitro?
And whats Nitro?
RE: FG 4x4
ORIGINAL: Apache-
WA
RE: FG 4x4
ORIGINAL: D0G
http://www.modellbau-friedel.com/cgi...D%20Umbau%20FG
heres the kamitiro 4x4 kit 375 Euros ......then you still have to purchase all this
1 6050 spur gear carrier
1 6051 rubber pucks
1 6427 plastic spur gear 46T
1 6431 oder 6431/1 steel pinion 16T
1 differential, complete
1 6048 oder 6048/1 differential spur gear 48T
2 6069/1 differential drive cups
1 6074/1 a-arms, rear upper
1 6076/1 a-arm turnbuckles
1 6029/1 ball joints M8
Another 150 Euros.......................525 euros ($675) $715 shipped for the belt drive......
849 euros ($1080) for the chain drive $1120 shipped......Crazy prices more than my MT[:@]
You could always buy the MCD buggy $1500 without a motor.... I dont think $1500 for a 4x4 plastic rolling chassis is a good deal[&:]
The MCD Truck $1680 without a motor.... nice another expensive rolling chassis....I guess if you have a monopoly you can charge the outrageous prices
I have a FG MT plastic rolling chassis......... anyone willing to pay $800-1000 for it???......I dont think so!!
RE: FG 4x4
Yes they are expensive those kits....
Or you can try the heiss 4WD conversion kit. Also not cheap but looks beefy as well and they have em for all FG models.
I'm happy with the 2WD as it is. But a 4WD one sure would be faster and able to climb where the 2WD will fail.
If you go 4WD IMO it is better to save up and buy a designed 4WD car due to the weight balance.
A re-build 2WD is basicly still "light" at the front. A conversion kit will add serious weight to the front but still the complete weight of the car is more set to the back than it should be if you ask me.
All is a question about the green leaves in the wallet though as buying a full new 4WD car surely ain't a joke and then a conversion kit might be in reach.
RE: FG 4x4
sorry guys
the heiss kit will not work
the most problems are with the front cvd´s
you will not have much fun with this kit
there a lot of guys in Germany who has bought this kit
and the most will never buy again
the problem is
the turning point from the hub is different to the turning point from the cvd
so it will not perfect work
take a look to the MCD Frontaxle
there you see the perfect way
MCD is the only one in largescale who had this perfect done
greets
Hunter
the problem is
greets
Hunter
RE: FG 4x4
Hi Guys,
WWS has a prototype 4x4, some of you may have seen it at the Powercup in Belgium, I hope to do some testing with it over the winter, but first impression looks very good.
Steve
Steve
WA
RE: FG 4x4
ORIGINAL: avgas
Hi Guys,
Steve
Hi Guys,
Steve
RE: FG 4x4
That looks pretty much like it hellya to the one I saw from WWS.
Good to hear from the Heiss kit first hand. I could not find any posts on it on the german forum.
RE: FG 4x4
dog
i have the new mcd mt and they are tuffer than fg by a long shot + 4x4 system is shaft driven and even though you don't hear alot about them they are true monsters and don't need beefing up as they are well built already got mine from www.sbracing.co.uk if you have any questions mail simon and i'm sure he will gladly answer any questions you have about the mcd 4x4 mt
RE: FG 4x4
Saw now some reports coming at the German forum and saw 3 out of 3 positive replies on the Kamatiro 4WD kit for the Marder.
Anyone here the same experience?
