Carson attack diff problem!!!!HELP
Hi ppl
i recently got a carson attack 2nd hand (=S) ive put large wheels and tyres on and noticed that the car is making a strange "clicking" noise wen moving......i stripped the diff out and noticed that the diff case was broken...so i replaced the case and nothing changed
my friend went out and bought a carson attack and i have noticed that the ring gaer on his model is not as wide as the ring gear on my model, so now i think that the diff on my model has been replaced by an FG diff
could this cause the problem...and do the Fg diff's fit on the carson attack
thanks for any help
greetz
thanks for any help
greetz
UT
RE: Carson attack diff problem!!!!HELP
Everytime mine made a clicking sound the mesh was wrong. The thickness of the gear shouldn't matter much I would think as long as its the same tooth count. I'm pretty sure the beefed up diff gears are thicker anyhow. Check the mesh between it and the engine. My XTM the mounts where so poorly made I couldn't keep the mesh set at all so I changed over to alloy mounts and haven't had a issue since.
CT
If the mesh is incorrect would it also make it whine when the car is rolling to a stop without any throttle applied?[]My hammer is doing this.Or does it need to be taken apart and lubed up?Haven't done it and it's been about 4 tanks of fuel.[sm=confused.gif]
hi
thanks for the speedy reply
i set the mesh up perfect and still the same...it seems as though the diff ring gear has been rubbing on the chassis
any other help wud be most appreciated
thanks
thanks
WA
Alloy mounts are a must.
I used up three plastic mounts in a year of driving, all stripped out and tore up gears as a result.
Make sure they are for the Carson or Firehammer not FG. The large mount is different.
ok
any idea where to buy parts like this for the carson attack
cant seem to find anything anywhere for this model
thanks
thanks
CT
Try these guys www.fg-hopups.com click on the firehammer link on the top of the page.The carson attack is a Hammer clone.[sm=thumbup.gif]
ORIGINAL: F30|r
ok
thanks
ok
thanks
ahh didnt realise that
so now on if i search for firehammer parts i should find it easier?
thanks for ur help guys
UT
ORIGINAL: F30|r
hi again
tryed ordering from the states
said it would take 2 - 3 weeks or $39 for 6 days
very expensive!!!!!
any1 no of anywhere in the uk that stocks firehammer or carson attack parts
thanks
very expensive!!!!!
thanks
you can use most fg parts with the carsons apart from fg shells and front bulkheads as the chassis is longer but it will take a fg diff
hi
seems as though i have an fg diff in my carson attack
just cant seem to think wot the noise is
doesnt do it at low speeds just mid range spped going over un-even ground
any1 had a strange "clicking" noise on there model?
thanks
thanks
WA
ORIGINAL: F30|r
hi again
very expensive!!!!!
thanks
hi again
very expensive!!!!!
thanks
it wont cost you as much shipping .......................lucky person
Zone 1 Belgium, Denmark, France, Guernsey, Jersey, Northern Ireland, Great Britain, Liechtenstein, Luxembourg, the Netherlands, Austria, Switzerland
1 kg .....9,50 Euros
2 kg .....10,50
3 kg..... 11,50
4 kg ......12,50
.................................................. ....it will only take 2-5 days
hi
well finally realised that it isnt the diff that is making the noise
but it was something as stupid as the gear cover hitting the nearside rear suspension arm wen going over a bump
cant believe it was that easy..thx anyway
any more places for spares wud be mostly appreciated
thanks
thanks
