ecu system
ecu system
is anyone useing one of these engine management systems?
they monitor rpms,temp an so on,,,
just curios[8D]
so no heavy handed replys pls!!
cheers
just after info,,
thanx
ps
like this one
120043178777 ebay item no
just curios[8D]
cheers
just after info,,
thanx
ps
like this one
RE: ecu system
Jump over to the forum at http://www.rctek.com
Iam Oddie(Who makes that specific ECU) and several other of the UK and European large scale racers often drop by there, and the ECU has been discussed a couple of times. You won't find many winners than DON'T use the ECU.
Here is a couple of direct links to an ECU thread.
http://www.rctek.com//phpBB/viewtopic.php?t=4140
http://www.rctek.com//phpBB/viewtopic.php?t=4287
RE: ecu system
do u want the adj. timing part of it or r u looking more at the rpm temp ect. aspects of it? if u just want the rpm temp ect look at the eagle tree alot cheaper and gives u speed. or the msd kicker ignition gives u the timing and a higher voltage spark again cheaper.
RE: ecu system
Friend of mine has one. When the track has a long straight it makes sense to use it, the engine can rev-up significant higher (saw it doing 23.500 RPM).
When the engine cannot rev to the max due to the track lay-out he takes it off to save some weight.
Unless you are really into racing and want to squeeze the last drop of possible power out I think it makes not much sense to put it on. Rather spend the money on something else then. For on-road it is much more a good hop-up than in off-road.
RE: ecu system
I just re-read the threads on the ECU, I can see that the inventor only uses it for On-Road.
He said at that time, that the off-road cars break easily enough at the speeds he can get without the ECU, so He won't use the ECU for off-road....
RE: ecu system
That was in the past I gues - Ian does use an ECU off-road as well as I recall from the waldrane race last year, more people use it but not many (so far). Also because it is not the cheapest gadget...
RE: ecu system
Hi Apache,
Are you doing Waldrane this year? If so, then I try to find you there or see me in the Brit camp, theres alot of us going this year as I think its the last one there?
Steve
Steve
RE: ecu system
Someday I am going to find myself one... Not for any racing value, but to satisfy my lust for technology.....
It was also that lust that gave me my Nomadio Sensor, and I haven't regretted it even once.
