High speed ????
High speed ????
IIt time to change Zenoah 26cc engine for my stadium truck I already have 2 speed gear and many ally parts, I’m looking for high speed… I need advise which engine I should select CY 29cc, CY 28.5CC , CY 30.5 CC , modify my Zenoah 26CC or there is recommendation .. coast is not a big deal because I don’t buy engine everyday and I’m willing to invest on quality engine.
A racer in France informed me that I should look to high rev engine ( high RPM) and I should not concern about engine size because I will never get high speed from engine delver high torque only.
TX
RE: High speed ????
Hi irenaslavo, This is one sweet 6hp Engine [link=http://www.oneillbrothers.com/rccar/itemdescription/ported_g260rc.htm]Oneillbrothers[/link] with a Jetpro pipe! The motor goes for $299. He has a 10% coupon code this month rcu-nov That coupon brings the price down to $269.10 Good Luck with whatever you get!
RE: High speed ????
Thanks ScooterTrash , but should I look to H.P of he engine or RMP, in Oneillbrothers they list 28.5 CC engine and mentioned it revs much more than 29cc engine, I don't know which one I should select.
RE: High speed ????
If you want the highest speed available on the market right now then you should look into dropping one of these into your truck. It is the same motor that wins the national level races.
RE: High speed ????
Yes, it has adjustable timing on it. It is a true powerplant for an rc car or truck. Combine it with a Samba pipe and you will make a Stadium truck scream.
ORIGINAL: J_D
ooh adjustable engine timing, is that legal ?
i think thats what i see on that case.
TX
RE: High speed ????
[8D] Hi irenaslavo, I would call Sean & talk to him to get the awswer that you are looking for! Tell Him Harley George sent you, He will do you right!
ORIGINAL: irenaslavo
RE: High speed ????
Thanks FG Perf RC, but what specs of MMR engine and where I can find.
please explain to me what is the meaning of adjustable timing
RE: High speed ????
RE: High speed ????
if you want some of the best, then you need an Oddified Heli Tune Engine with an Oddified ECU, and a Bolt On Reed Valve kit. Tell Ian Oddie that you want maximum Speed, then He will get you there....
But that setup is customized and way over US$ 1000
http://www.oddified.com
An ESP engine with bolt on Reed and the Oddified ECU will also get you there, but at a more human price point.
Tthe Oddified ECU gives you a computerized Ignition, with only 2 wires connecting it to the engine.
RE: High speed ????
ORIGINAL: JRexA
RE: High speed ????
Thanks JREXA for your advise but as far as I know reed valve can not be bolt on off road engines.. please correct me if I'm wrong also the controlling ignition time will increase 300 r.p.m
Although I’m willing to pay such amount of money if I will really get what I’m looking for, I would like to know why Oddified tuning are more expensive?
Now I checked his web site and last update was in 23/9/2005 and he don’t have contact numbers or address… are you sure he still operating?
RE: High speed ????
oddified engines are expensive due to the fact they dont come any better & are found in most winning drivers cars in europe & worldwide comps,he doesnt just tune engines he races cars too and has held both on & off road overall no1 world champ spots numerous times,and yes they still operate as they only specialise in a few model services on there site - clutches,engines,diffs,tone servos,ecu & a few other tuning parts.unless you intend to run in serious comps then your better of buying a ported or displacement motor from oneills ect for alot less $$$
RE: High speed ????
i wouldnt mind any fully worked tuned engine - oddified,pase,stuffgart or the mmr you posted,but @ £400-£500 will they make me drive better or just make me crash faster
RE: High speed ????
You sure do get to the other side of the field or parking lot faster with a modified motor. Should really consider getting a set of hydro brakes on it to help stop it too.
TX
RE: High speed ????
[8D] I still Say! the Second Post is the Best buy for the $$$ & FAST[sm=thumbup.gif]!
ORIGINAL: ScooterTrash
ON, CANADA
RE: High speed ????
There is a guy who can mod motors in Toronto. He has driven on-road cars for years. Take a look at his site and contact him. (Dino)
PLus he distributes the RS5 Carbon on-road cars!
http://www.samba-rs5.com/motor.htm
