FG MT gears info
NC
FG MT gears info
Hello,
What gears are you guys running in your MTs? I run 1st gear 18/46 and 2nd gear 20/44. I was told 16/48 and 18/46 would be a better choice than what I am running, with the 18/46 and 20/44 I would more than likely snap some kind of pin in the gears or something. I like the gear ratio I have right now but, I would like to know what others are running. I will hopefully be ordering them Monday, because of Thanks Giving. Its killing me just sitting here looking at MT out of comission. Oh, I am a basher. I bash in a pretty BIG Industrial Park parking lot or at a Sand & Gravel Pit.
Anyone out there with a MT and a 2 speed. What gears are you running?
Any info would be greatly appreciated.
RE: FG MT gears info
ORIGINAL: T I G
Hello,
Hello,
TX
[8D]Hi Tig, the 16/48 and 18/46 will give you more pulling power {off the line or hole shot} & the 18/46 and 20/44 you would have more top end! You would be more than likely snap [:@] some kind of pin in the gears or something with the the 16/48 and 18/46 set up! But I don't think it would snap anything! Stock FG MT-5 has 16/48 & with a ProJet pipe!, All is well,[sm=thumbup.gif]
ORIGINAL: ScooterTrash
ORIGINAL: aluminum crusher
I have the 18/46 to 20/44 set up and I have not snap anything no pins or nuts or bolts etc.
With this gearing and a Jetpro v1 unsilenced pipe my truck would do wheelies on command and reached a 300 foot drag race speed of 49mph Confirmed by a (real mounted in cop) car radar gun
Good luck!
ORIGINAL: chowderhead72
I have found this ratio works well with the monster tire package with a tuned pipe. Personally I like the 48/16 and 42/22 for great all around performance. This combo provides wheelies and top speed. The only issue is when driven hard you will break the shift pin in the second gear carrier. If this occurs it is a simple fix; just drill out the hole (where the shift pin came from) to accept a 4mm bolt of suitable length and you are back in business.
Good luck!
Good luck!
[/quote]
Yes you will surely hear a shift. Have you EVER heard it shift?
Yep that sounds good and sweet but I did not want mine to hit wheelies when I smash the throttle so I opt for the 18/46 to 20/44 and it's fast I just don't hear it shift into second gear, what about you do you hear yours shift.
[/quote]
NO not yet.
NC
02f350psd,
I live in Waltham. I used to live in Randolph.
Chowderhead,
Thats the pin, the second gear shift pin. Is it ok to have such a spread in gears (16/48-22/42), I was told to stay within 2 teeth when choosing pinion gears.
I wonder if swapping out the pin in favor of a 4mm bolt would be a decent mod to prevent this from happening.
I like the performance out of the 18/46-20/44, I am not sure that I would like wheelies every time I romp on it, occasionally yes, not all the time though.
Thanks for the help guys, I appreciate it.
Chowderhead,
TIG, I tried all gear ratios available for FG , I believe the best ratio is 16/48 and 21/42 if you are looking to drive without a risk of damaging pin for second gear, if you would like to take little risk go for 22/42.
If your engine size more than 26CC, 18/46 and 21/42 will be good choice also
I use to turn screw of second gear shaft ¼ turn anti clock to get faster engagement of second gear, you will not hear sound of second gear easily but you will feel speed.
TIG, the CY 30cc is powerful engine I believe you don't need to go for 16/48, the engine will let your truck accelerate good unless you like wheelies, for 21/42 , for the 21 gear it is easy to recognize because it is not plastic or steel, the gear made form alloy which is extremely light and it is anodized with very dark brown color
Good Luck and have fun
NC
Man, I'm so mad[:@]. I ordered a single pinion gear for my 2 speed, just to get me going. He sent me a gear for a single speed[sm=48_48.gif], AAAARRRGGGHHHH, now I have to wait another week or two. Man, I just want to go bash. I have been using my Nitro Truggy and my daughter Buggy, its just not as fun, plus tuning it sucks.
Anyone want to trade a 1/5 or 1/6 scale heck if you have a 1/4 scale lying around collecting dust.
I have a Jammin CRT RTR with Picco FT .28 , CRT Pro Clutch assembly, CRT Pro motor mount, Ofna 12V starter box, 3 new wheels for starter box. Its is in near mint condition.
Are you sure you are talking about a pinion gear or a spur gear? The pinion gears are all the same for single or 2 speeds. Only the spur gears are different on the 2 speeds.
NC
Yup, I am sure. My 2 speed pinions have an oval/oblong center. The single speed has a round center. BUT, the single speed pinion can be used with the included set screws. I just didnt think it would hold up. The last thing I want, is to lose a pinion out in a field or a parking lot. I did use an extra set screw that I had lying around and used a little lock tight for extra security.
I actually just got back from a little bash session with my daughter, she has a GS Storm.
Unless there has been a recent design change that I missed the shaft shape is the same on the two speed clutch bell and the single speed bell. The different shape is on the layshaft where the final drive pinion meets the diff spur. Clutch bell shafts should be oblong with two opposing flats (football(NFL) shaped)
