Carson attack gears
Carson attack gears
I have read in the past that the FG gears don't fit the Carson attack ,
I would like to gear it up to 20/44 as I mainly use it on tarmac ,
Does anyone make gears for this car ? if yes where can I buy them.
Many thanks
Damian
RE: Carson attack gears
the FG gears Spurs fit perfect, you will have to experiment with pinions to get mesh. The span between the gears is different then FG.
prob cheaper and easier to swap the carsons gear carrier + large engine mount for the stock fg ones so you can use all the fg gears
WA
You can use the stock spur here are your options as far as pinions http://www.rc-car-online.de/htengritzel.htm#a
17, 18, 19, 20 tooth
