B5 best oil mix?
MN
RE: B5 best oil mix?
[link]http://www.rcuniverse.com/forum/searchpro.asp?phrase=gas+and+oil&forumid=234&timeframe=%3E&message=both&topicreply=both&timefilter=0&top=300&criteria=AND&sortMethod=d[/link]
Banned
for the first run, use the oil HPI sent with the baja to 1/2 gal of gas. this will gvie you a 25:1 ratio and about 2+ tanks worth of fuel. On your first start, let it run for a few minutes to warm up well, about 3 or 4. Once the motor is warmed up decently,drive it like you mean it. , but dont hold it on wot just yet. run it, run it hard, just dont wot it the whole time for the first 20 minutes. once 20 minutes have passed, start to run it like you stole it. be sure your needles are set rich and check your plug color to check how your motor is running.
keep a few extra plugs on hand as you may need one or 2 on a new motor. ideally you should be running rich, which will foul plugs.
once you run the oil HPI sent with the Baja, then use quality Fully Synthetic 2cycle oil like Klotz Supertechnoplate ( what i currently use ) or AmsOil Sabre Profession or similar quality oil at a ratio between 25:1 and 40:1. most run 25:1 - 32:1 typically with 87 - 93 octain pump gas usually. 2 best pieces of advice, Use Quality oil and watch your plug color for tuning indications.
SBG
SBG
