Brake square
Brake square
Hi All
My brake square on my marder keeps working loose should i use super glue on it or locktite it is only held on with 1 grub screw
John d
[&o]
John d
[&o]
AB, CANADA
RE: Brake square
May want to also pull the grub screw out and file the tip of it flat if it has rounded itself. And check the threads on the grub screw and the square. I had my threads come all apart and no matter how tight it felt, it would slip..Then Loctite to finnish the job.
MN
RE: Brake square
Grub screw on tire squares replacement and filing. And use blue or red locktight both work for backing out problems.
http://www.rcuniverse.com/forum/m_42...tm.htm#4281326
RE: Brake square
Yes thankyou all for that i had not thought of filling the grub screw flat i will give that ago and locktite it in
Thanks again
John d
Thanks again
John d
