Small photo request
NY
Small photo request
I am wondering if someone could take a few photos of various brake setups on the different models. FG, Baja and so forth. Trying to design my brake setup, and would like to see if I can use existing ones. Thanks.
RE: Small photo request
Try downloading the FG catalog and browse through that one.
You can find it here: http://www.molzermoweryracing.com/do...4FGCatalog.zip
Here you can find the different FG Mounting instructions, that should give you some info about the Brake setup.
http://www.fg-modellsport-gmbh.de/FG...-Archiv_e.html
FL
RF, LF cable. Center rod connects to third channel servo
LF brake
LF brake from top
Note: above bearing supports & lower arms have been upgraded from oroginal plastic. If you use original plastic parts, the brake is attached from the front. FG on-road car.
