Baja Engine Problem
Baja Engine Problem
Well I took the baja apart to get rid of that ungodly purple. Reassembled and it just wont start. ran great before I took it apart. Fuel tank is breathing ok. All gaskets/Seals are tight. New spark plug. coil mags ste at .010. completely removed cleaned carb. Great bright blue spark. Compression seems good. I am completely stumped here. Any Ideas you guys may have woud be more than appreciated!
Banned
BC, CANADA
RE: Baja Engine Problem
how did you check the spark? With the plug pulled? Not the best way if you did, find your self a spark tester it will show what kind of spark you have in the motor. As this can differ from what you get from just pulling the plug and testing it that way.
yes thats how i tested it, just pulled it and let it rest on the head. perhaps thats a better way is to get a tester. Gotta tell ya this has left me scratchin my head.
ORIGINAL: Recon8541
Thanks for the tip on the kill switch. Im pretty certain its not that, as I am getting spark. one thing I did notice upon removing the prefilter and air filter....the airfilter is soaked with gas...thats odd, I just dont know what it means....pretty new to all this stuff.
well if the filter is soaked , it might be flooded turn engine upside down, take plug out and pull it a couple of times to see if fuel comes out. Also make sure choke is closed!
UT
ORIGINAL: Recon8541
