Fast help!!!!!!
Fast help!!!!!!
Ok guy i'm in the middle of fixing my truck but i'm having a little memory problem.[:@]
Do any of u guys have a pic with the tranny removed to the point were u see the brace that holds the motor?
The point were u just see the clutch shoes. these braces http://www2.towerhobbies.com/cgi-bin...?&I=LXPMR1&P=7
And does any body know were this goes? http://www2.towerhobbies.com/cgi-bin...?&I=LXPMN3&P=7 ?????
I need an answer FAST!!!
RE: Fast help!!!!!!
The triangular brace goes on top of the rear bulkheads (rear two screw points) and the large plastic engine mount for the third screw.
Set your gear mesh before tightening down this brace.
RE: Fast help!!!!!!
Thanks man
I got it figured out now thanks, mesh OK. I don't know what my prob is with the truck. all there BB are fine, The diff had tons of grease, The mesh was fine. I cant figure out why it squeals? I even took out the clutch pads to see if it was the motor. I even started it and no wine coming from the motor, so what is making the noise?
I should ad I'm still putting every thing back together so i will no tomorrow if the noise is still there?
WA
RE: Fast help!!!!!!
removing the tranny is alot easier than you made it to be.
Remove the upper arms in the back fro the tranny brace
drop the bones
remove roll cage
remove the rear upright
remove one or both tranny braces with the tranny.
5 minutes of work.
Your problem is most likely your wheel hexes are spinning (not tight)
Please describe your problem more..
drop the bones
remove roll cage
5 minutes of work.
WA
RE: Fast help!!!!!!
I found out along time ago how to put togerther stuff by using a camera to get a (before picture) of what I was working on.
Also you should have a exploded diagram that came with your owners manual read it, study it keep it..
WA
RE: Fast help!!!!!!
Copy and keep this.
Its for a FG marder so the numbers will be differnt but the assymbly is the same.
http://www.fg-modellsport-gmbh.de/_P....6000-6004.pdf
