Pls post ur Engine size and hp?
IN
guys just wanna know the different engine size and hp of ur truck, pls mention if stock or mod...just doin little research.......thanks..
VA
RE: Pls post ur Engine size and hp?
hmm. well i dont have a dyno or ever had mine dyno'd but ill tell you this! i have a 26cc in the truck with a ddm mid-top range pipe and a very thin copper head gasket and it pushed this heavy boxy hummer up to top speed very quick.. ill guess HP is now 4.0 or 4.5 ... just a guess so dont raise the BS flag on me yet
ORIGINAL: TheFgMan01
From the little dyno testing I did, and other reputable people I know that have a dyno going now, my best guesses would be
Stock G260 with stock can 2.3 (my testing measured)
Stock G260 with no exhaust--like Zen tested them (2.78hp in my test--zen claims 2.8hp)
Stock G260 with a decient pipe 3.75hp to 4.2hp (my test measured)
add porting about 5hp (my guess--I don't have the use of the dyno anymore--and have to make my own).
add a reed and use the good pipe---about 6hp (my guess)
Big bore, big stroke (36mm bore and 2mm stroker crank for a 30.5cc engine)--close to 7hp with a good pipe (my guess, and a qualified operators dyno results on his engines).
I think these numbers are pretty close to actual in most cases--at least from what I have seen.
IN
WOW! this is a great info guys,,thanks alot.
i noticed that the 26 motor and 30 motor moded has very keen difference both claiming 6-7 hp though, what u think guys which way to go considering price wise, weight and parts availability?
IL
My FGMT with stock zen 260 and stock exhaust hooked up to a little red wagon pulled my fat ass up and down the street. I don't recommend doing this, but I wanted to see if it would. I weigh 253 lbs.
IN
post pics here next time,,,this thing is real awesome and funny cool!!
bet ur covered by smoke behind!!lol..
[sm=thumbup.gif]
ORIGINAL: Bratch96
ORIGINAL: Bratch96
FL
I have a fully ported 26cc Zenoah cylinder reed engine, all work done by O'neil Brothers, with a Monster Marder Jet Pro, lightened flywheel, and and OB stuffed crank. This engine is estimated at 6.2 to 6.5 HP (still waiting on Sean to dyno one for me). The major difference in the 30.5cc and the 26cc making the same HP is the RPM and torque. The 26 will rev higher giving more top end, while having descent bottom end, and the 30.5 will accelerate faster, having more torque than you would ever get tired of. Both are great engines, but I perfer the higher RPM and hence have a 23cc on the way to stat modding.
Check out the Review I did on the 26cc reed engine, it has videos too. [link=http://www.rcuniverse.com/forum/m_5338107/anchors_5338107/mpage_1/key_Cylinder%252CReed/anchor/tm.htm#5338107]Reed Kit Review[/link]
Well here goes my list.
26cc - Zenoah G260 with Jet pro pipe about 4hp
29cc - CY with 2mm stuffed crank and x-can about 4.5 hp
23cc - Zenoah G230 with tuned pipe ??
My Zen 23cc oddified 5.7hp @ 18,750 rpm, 3.0Nm of Torque.using Samba leopard pipe.
The motor is approx 2 years old but has been maintained regardless of cost.
The New Heli oddified motors have even more power and torque.
IL
ORIGINAL: JUCD VPR
[/quote]
I don't recommend it. It was just putting along. It naturally wants to spin the tires on the asphalt, I think the engine was getting pretty hot so I didn't do it too long.
If these trucks were any bigger they would be gokarts, we could call them "pocketkarts".
what is the fastest engine i can put on my stadium truck? i am not looking for power i am looking for speed . what does a engine like that cost and where can i get one?
also if i put that kind of engine what all do i have to upgrade?
also what kind of hp will i get and what will the top end speed be like?
