CARB WONT SUCK FUEL
CARB WONT SUCK FUEL
MY FG TRUCK WITH A G26 WAS RUNNING GOOD THE IT JUST QUIT RUNNING AND NOW IT WON'T PULL FUEL IN TO THE PRIME BULB .ANYONE HAVE ANY IDEAS.
VA
RE: CARB WONT SUCK FUEL
take the black line off the carb, hold your finger over the line and press the bulb to see if you feel any suction. if not the prob is in the carb. if you have suction you have a glogged line or fuel filter... have you tried that yet?
VA
yeah... unscrew the bulb on the carb and there will be a gasketand very thin diaphram... i'd make sure that diaphram is clean enough to see through. thats the only thing i can think of... i dout your lines are hooked up backwards... yellow top black bottom right?
VA
hard to diagnose thise problem.. he only has 1 gal. through the truck.. he never mentioned if her was able to get fuel to the motor with his friends carb.
