Exhaust bolts
RE: Exhaust bolts
ORIGINAL: oldman65
I worry about lock thight on exhaust. Wont the heat seize the bolts into the cylinder?
Good luck
UT
RE: Exhaust bolts
ORIGINAL: oldman65
Does anyone have a fix to keep the exhaust bolts from backing out. I'm running a dominator pipe on a Baja
RE: Exhaust bolts
Um,
We heat Locktite to get it off. One of the hottest parts of the engine is the exhaust and head. Locktite will not work. Use spring or lock washers.
UT
RE: Exhaust bolts
ORIGINAL: Billyfunnyguy
Um,
Um,
"246 Threadlocker High Temp./Medium Strength
This threadlocker resists oil and mild surface contamination at continuous temperatures to 450°F. Suitable for fasteners between 1/4" and 3/4" (6 to 20 mm) diameters.
Loctite makes thousands of products and it does work on exhaust bolts very well.
RE: Exhaust bolts
please red is fine for cap head bolts .. they come out with no issues just alittle tighter and hold up better ..
ORIGINAL: badz
Use blue locktite...don't use red
ORIGINAL: oldman65
NM
RE: Exhaust bolts
Well guys, I think I will try blue locktight first and if that doesn't work then I will try red. Lets not argue over this. What ever works best is what should be used.
I didn't know if anyone had the same problem.
Thanks for all the suggestions...
UT
RE: Exhaust bolts
ORIGINAL: oldman65
RE: Exhaust bolts
Currently i am having that problem with my x-can and i have put blue
loctite on the screws but after running for about an hour or so the screws back
right out. [:@]
At this point i guess i might try the red.[8D]
right out. [:@]
RE: Exhaust bolts
I thought lock tight melted at about 250 or 300 deg F. It is quite a bit hotter at the material right next to the exhaust port.
Try lapping the gasket surface of the exhaust port, and the end of the pipe flat. Those screws comeing loose are not a supper common problem---and the surfaces not being flat is just my best guess on why.
SD
RE: Exhaust bolts
I have found BLUE lock tite to work excellant in every RC car application as long as I do the following:
Make sure the screw and the screw hole is very clean, by spraying brake cleaner on the screws and in the holes. Let the brake cleaner dry up before applying lock tite.
Secondly, allow the locktite to sit 24hrs to cure. (YEAH, I know it dries faster than that, but dry does not mean Cured)
Heck, I often have to heat the head of screws with a soldering iron to get BLUE lock tited screws out. I would need a tourch to get them out if I used RED.[sm=47_47.gif]
Simply my experience.
Electronjunk
Electronjunk
RE: Exhaust bolts
ORIGINAL: badz
ORIGINAL: oldman65
Really? Whoever told you this obviously knows nothing about Loctite products. I've yet to see a RC Exhaust hit 450 degree's.
Learn before making assumtions please. Loctite makes thousands of products and it does work on exhaust bolts very well.
RE: Exhaust bolts
ORIGINAL: Earth Surfer
RE: Exhaust bolts
ORIGINAL: badz
Um,
Um,
NM
RE: Exhaust bolts
Well I just got my replacement parts for my 27.2 Zenoah from ESP so I will put it together tomorrow and use blue loctite on the exhaust bolts. I'll run a full tank and let everyone know how it works.
RE: Exhaust bolts
I use fg green loctite on exhaust bolts, Very strong stuff and can still remove them easily when needed, The part number is fg 6504/1 screw retention, high strength
Simon
Simon
RE: Exhaust bolts
Well guys i have a confession to make. I was reading that infamous..Freddy
Kruger vs Jason Vorhees...oooops i mean Badz vs Ryan from DDM thread
and i noticed on one of the photos Badz showed the X-port on the exhaust
and.. WHAM...it occured to me that the x-port should be mounted directly on the
exhaust and not inside the can itself. I was wondering why when i first got it
there were 2 gaskets and also why the x-port was not lining up with the holes
properly. To get to the meat of the matter maybe that is why the bolts keep
on backing out.
Well for all the novices like me out there don't make the same mistake. [sm=lol.gif][sm=lol.gif]
on backing out.
RE: Exhaust bolts
On another note i decided to put back on the stock pipe because the X-can
is too loud and wherever i run the baja the loud sound causes alot of attention.[8D]
I have the 29cc with stuffed crank motor so i feel the power should still
be adequate.
be adequate.
UT
RE: Exhaust bolts
hey at least someone looked at the pics hehe...i've been using the stock can and even cleaned everything out of it and dont use the stinger and the power from it is pretty pathetic compared to what the dominator gave it...i run a 29cc stuffed crank engine also with 8000rpm clutch spring...it's way more power than stock but just takes forever to really hit the powerband on the stock pipe
RE: Exhaust bolts
Well badz i just don't like the look of the tuned pipes out there and i never liked the
fact that they melt some of the plastic posts.I must admit that out of all of them i
liked the "black"Dominator pipe because it blended in well with the black posts at the rear of the BAJA 5B. [8D]
