did i kill my servo
CA
did i kill my servo
I replaced the screw that holds the servo arm on my hitec steering servo with a longer one,after i tightened it,it locked up and wont move so i back the screw out a bit then it unlocked but servo is not working anymore,i think the longer screw damaged something inside,has anyone ever done this???
CO
RE: did i kill my servo
Pull the four screws out of the servo and remove the top of the servo to access the gears, I suspect that you may have cracked a gear.
I guess that I should ask if the servo makes any noise like it's trying to function?
Banned
Never put a longer screw in anything!!!!!! Only use the MFg. supplied screws. Always have extra srevos in case this happens. It can ruin a day of racing.
