pipe breathing heavy smoke during rum time....
My Feedback: (9)
is it fine ? my Mb is breathing exhuast air out alot? med cloud of smoke, or is it suppose to be less smoke? it runs strong. check the plug few times it light black color
FL
RE: pipe breathing heavy smoke during rum time....
Smoke is actually a good thing and has everything to with tuning. It sounds like you might be running on the rich side... As long as you are not fouling plugs it won't hurt anything, but you won't have top performance either. I personally run mine a little on the lean side in cold weather and a little richer in warm weather. A faint cloud of smoke is what you want for good, safe running.
VA
i also noticed it depends on how much oil you mix in also... i stopped using 50:1 and it's puffin out alot of smoke now
