Are carbs on Zenoha and CY engines the same?
Reason i ask is that i got hold of a CY engine and want to put the carb on my zenoah! I know the engines themselves are meant to be slightly different qualities, but are the carbs or are they manufactured by the same people.
Guy
Guy
UT
RE: Are carbs on Zenoha and CY engines the same?
Zenoah engines come with the Walbro WT-603 carb. CY engines come with the Walbro WT-668 carb. Performance is similar between the two, and they are interchangeable.
My Feedback: (34)
If you have a 668 take it and run it. If it is a 603 throw it away and replace with a 644 or a 668. They are light years better and will not put your engine in danger of leaning as they hold their needle settings a 100 times better than a 603. Been there done that.
Curt
Curt
