boost bottels
boost bottels
I found a site on the net which does them for mini motos but also do a kit for the zenoha engines and cy.
Complete DUAL bottle kit for the G230RC and
several different Go-peds, and R/C applications.
Both bottles work in unisen catching both, the back
pulse of the piston and the up pulse. each bottle
has its own characteristics. Adds HUGE gains in
power and acceleration. Bolts on directly too!
Manifold included for free! typical gains are 6-10MPH!
Go-peds: Fits All G230RC* / G260RC* / G260PU* / G260PUH* / G231PUH* / G231PUM* / G260PUM* engines. Also fits Chung Yang CY23RC / CY26RC / CY27RC / CY29RC / GP290 engines. Works with Walbro WA / WT series carburetors
This kit is a great addition to boat and buggy applications!
-For boats: fits directly into the foam core tubes for a
clean snug fit.
-For R/C: Looks sweet on all FG, baja5b, Maurder, etc..
are these any good??????
http://www.boostinductionsystems.com/home_003.htm
clean snug fit.
TX
RE: boost bottels
yeah they are ok,they dont have any nos in them,it just gets the burnt gas that usually gets sucked back into the carb out of the way and puts it in the bottle then reuses it and gets rid of the bogging.so there fore you do get a little more power out of it.
RE: boost bottels
Not sure what BigModMan is talking about, because there is clearly "Whip-its" NO2 bottles that go inline with it. I just wonder if it is a constant feed thing, or if there is a remote trigger that can be set up to a servo that can control the burst of injected nitros rather than what looks like a needle valve bleeder that allows a steady flow until the bottle goes empty.
In theory, it would really well if you had a third channel set up with it and a trigger.
RE: boost bottels
You guys are talking about two very different things.
The boost bottle similar in concept to the ones made by mip and others works with the carbs to create vaccuum and pressure at different times in the motors cycle. They make a difference mostly on the bottom end. Fg makes one of these. Part number fg7495 I have one that I would sell cheap if interested.
The second that dave Espi is talking about is a mini nitrous system that works off little cans of nitrous (bakery type canisters) and a series of solenoids and valves that connect to the reciever on the 3rd/4th channel. I believe Oneill brothers sells or use to sell this system for $200.
RE: boost bottels
so these bottle booster's increase speed by 6-8mph for $17 , on there site the one for r/c's sell for $17, thats all you need to get a few extra mph? if so ill buy one and try it out[>:]
RE: boost bottels
Hi guys,
I just ordered a boost bottle from Jim at boost bottle induction systems. I have a friend with a FG eco line with a 2 speed , so I'm going to race him with my carson C5 and see if these bottles make a difference.
RE: boost bottels
[X(]what site did you find these kits for $17 the only site i can find they want $43.[]
a link would be great.
Thanks guys.
Thanks guys.
RE: boost bottels
He already gave the link, but here it is again: http://www.boostinductionsystems.com/home_003.htm
The Single bottle ones are in the US$ 16 range.
