fh bodies
CT
RE: fh bodies
ok i found one of them but its not in stock http://www.largescalerc.com/Vehicles/Bodies.html
its the one that is $197 its the beetle conversion for the marder which is the same
CT
RE: fh bodies
RE: fh bodies
I looking into using .060 lexan and make my own body. Was thinking of cutting it out kinda like this setup that I found that another gas racer did. Looks like it would be fairly easy to do and it would be very cheap to make plus I can paint the body on the inside then. Something similiar to the pic below.
CO
RE: fh bodies
I am waiting for the FG Baja roll cage and body befor i switch out the stock body. Right now i will be useing Top Flite Lustrekote on the stock body. Have a few cans, tested it, and it holds up to gasoline real well.
CT
RE: fh bodies
That does not look like a good idea looks like you would take some bad damage if you rolled
ORIGINAL: wyd
WA
RE: fh bodies
ORIGINAL: Slammed
ORIGINAL: wyd
No damage from roll overs, and there were many..
The original body was tore up so bad this was the best way to save it and it was the perfect way.
RE: fh bodies
ORIGINAL: teamchrome
Thats a pic of my old XTM buggy..
ORIGINAL: Slammed
ORIGINAL: wyd
RE: fh bodies
I 'Baja'd my Firehammer body like TeamChrome did. It seems to work well. I had the same problem - too many rollovers caused cracks in the 'A' and 'B' pillars of the stock shell.
That VSMotorsports body is cool. Someone here recently mentioned that their MCD Baja 1000 body (looks identical to the VSModelsports body) was a mud catcher. The wide fenders stopped the mud from flying away from the vehicle and packed in under the body. I'd have to pass on this body if that is the case.
Just my $0.02
Just my $0.02
RE: fh bodies
The carbon decal sheet from Parma is very cool. I use it alot on my touring car stuff to make things look carbon like my personal transponder and top of my servos.
