Smart tech 1/5th m.t. low end bog
Hey guys i am kinda new to the 1/5th scale area and have a new smart tech m.t.. I was wondering i have a problem in the low end running with a bogg. i have tried adjusting in different ways and doesnt seem to help.
The truck has great top end and runs great just doesnt seem to take off as well as my friends firehammer. Any help would be greatly appreciated thanks jeff
RE: Smart tech 1/5th m.t. low end bog
ORIGINAL: busa 2002
mines the same way.need a pipe like ddm.the fire hamer has smaller tires is the reason for more punch off the line
The truck may not scream off the line but it shouldn't bog no matter what exhaust is attached. If you are nailing the throttle from zero and the engine bogs down like it wants to die it might be the carb settings. The stock settings for the H and L screws are roughly 1.25 - 1.5 turns out. Simply turn them all the way in (don't crank them real tight, just slow and snug) and then turn them out to those settings as a starting point. Run the truck and see how it does. You can tweak the needles in small increments to get to the desired point while running it.
There are many threads on engine tuning if you search for them.
well got my ddm pipe put on today on my FH MT and i realy moves quick.i punched it and when it gets on the pipe it just pulled up and flip on roof.did this few times.it has more low end than stock but its power comes very strong from mid up.only has 2 tanks through now so it should get little faster.i think wheelie bar time.
