I need a Firehammer gas tank
CO
My tank is leaking, so i need a new one. I checked at Tower, and Largescalerc.com, but they are out of stock. Is there any other place i could look, because im out of ideas?
CO
RE: I need a Firehammer gas tank
I emailed them, and I will call on monday. Why is this such a hard part to find? Is this a common problem with these tanks? I noticed yesterday that gas was leaking around the seam in the middle of the tank.
You could just go to you LHS and get an airplane tank and use that in the short run I'm sure with a tiny bit of modification.
EDIT: I have a bad case of teh typos this year... argh !
HobbyPeople has it for the Grizzly (I'm not sure if the Firehammer gas tank is the same as the Firehammer MT gas tank). The Grizzly is exactly like the Firehammer MT.
[link=http://www.hobbypeople.net/gallery/146413.asp]Tank-Link[/link]
I also have two tanks on order. My stock one is leaking a little. I did just seal it around the seam with a clear silicone sealent. I have not rac it since doing this but I'm pretty sure this will fix it.
I did email Duratrax about finding parts and why the problem is ongoing. THey did respond that parts will be here mid July so that means anytime the parts will be off back order. Bad thing is they didn't actually fully answer my question about why stuff is on backorder so much. More than likely they don't order enough to keep in stock at their business so everyone else suffers because of their bad planning.
ORIGINAL: NitroBurn1
I hope they get a lot of email, and phone calls about this, and maybe they will fix the problem.
I hit a curb real hard once and my tank cracked pretty bad. I had my LHS order an XTM Grizzly tank because the Duratrax tank was on back order. I about fell out when I went to pick up the tank and it was $40! The tank is $4 on Tower Hobbies. I paid the $$$ because the LHS has always been straight with me and I wanted to get running again.
I also needed some shock ends for my FH. Tower was out so I ordered XTM parts from Hobby People. I paid about 4 times what Tower was selling the same Duratrax parts at.
Bottom line is that XTM parts appear to be alot more expensive than Duratrax. I only order XTM parts if I'm in a pinch.
I only order XTM parts when I have to as well. I had to order dog bones and knuckle arms (under warranty and Hobby Services said they *might* have them at the end of June to ship a set to me). Well, no knuckle arms so I'm just glad someone had the XTM parts. I would say try tqrcracing.com but I have been waiting on an order from them since June 14/15. Their parts are cheap, but they aren't reliable and their service isn't very good.
Its sad because I use to race an XTM X-Cellerator and parts are cheap whether my shop go them for me or I ordered from HobbyPeople. Really sucks to pay 40 bucks for a tank that cost the shop less that 4 bucks to get. I looked today while at my buddies shop and cost is less than 4 bucks for a new FH tank so no way should a Grizzley tank cost 40 bucks. Talk about getting raped over the coals.[X(]
My shop just placed a large order of parts for me so my FH will be stocked up with parts (most I will never ever use). I did go for alum rear hubs and rear shock tower as they are not too expensive if your shop helps you out a little. Also ordered all the gears so in another week or so I will have a good selection of parts and the shop ordered some extras to.
That Grizzly tank is 20 bucks from HobbyPeople. 40 bucks for a tank is ridiculous. I picked up an extra tank from Tower last month when their supply was low. I like the 4 bucks better.
CO
I bought 2 from a place called Hobby Fever. They must have only had 2 because after I ordered, the status said out of stock. Quick service from this place, they already shipped.
i have the fix to all your problems with the firehammer.
i had a firehammer too
do as i did.
sell the firehammer for what ever you can get for it than buy a Baja and than start having some fun.
Dirby
do as i did.
Dirby
