RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
engine tuning - first run - bogs
Reply
Old 07-07-2007, 12:26 PM
mbe301
mbe301's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default engine tuning - first run - bogs
Hey All
Trying to get my engine running. It starts fine, but as soon as I give it throttle, it bogs and dies. At first I thought it was a fuel line that was slightly pinched (was too short, made a u-joint to reconnect and get ride of shrp bend) Still the same problem. That and I have almost no info on the engine (needle settings, etc.) It's and RCX-RC2 buggy.
Any help would be great, really want to try it out today.
mbe301 is offline
Old 07-07-2007, 02:19 PM
redramuk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: engine tuning - first run - bogs
screw both the carb needles in fully and screw them both back out 1 1/4 turns, i find this always works as a good starting point for me then tweak and tune as necesary, not an expert myself but hope this helps alittle
redramuk is offline
Old 07-07-2007, 08:34 PM
mbe301
mbe301's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tried it, no luck... I think I have an airleak somewhere. It doesn't matter where I have the hsn, it bogs with any throttle.
mbe301 is offline
Old 07-07-2007, 09:13 PM
T I G
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So, it will start and idle. correct.
When you hit the gas, does it stall?
Make sure your adjusting the right needles, it may sound silly but it happens. I did it .
The same thing was happening with my Baja, it started right up but once I hit the gas it stalled. I thought I was adjusting the right needles. When in fact I was not.
If its bogging of the line wouldnt it be the LSN?
What kind of motor is it?
What size motor?
T I G is offline
Old 07-07-2007, 11:17 PM
Slammed
Slammed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how bout the exhaust bolts if they are loose you will have a leak
Slammed is offline
Old 07-07-2007, 11:35 PM
NitroBurn1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, if the exhaust bolts are loose you will have a leak. I saw this on an HPI Baja tuning video.
NitroBurn1 is offline
Old 07-08-2007, 03:36 AM
MrMikeG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
check that the carb bolts arent going all the way threw the manifold and pressing on the block
MrMikeG is offline
Old 07-08-2007, 07:22 AM
wyd
wyd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My FH started right up in 3 pulls and ran well but during the first run it also bogged but not near enough for the car to shutoff. In my case I found that the richer I made the lowend needle the less lowend bog I had. After I richened up the lowend needle I had to turn up my idle screw to keep it idleing correctly.
Funny thing is on at least my motor you don't need to move the needles very far to see what the motor is doing. A little too far in any direction on the needle and the car lets me know right away by bogging badly or hesitating. With my stock pipe or my Jetpro.
wyd is offline
Old 07-08-2007, 09:20 AM
R.Robinson
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Everyone overlooks one thing? You have a air leak in the carb. Adjusting the settings is only a temp fix. The problem will come back again.[]
R.Robinson is offline
Old 07-08-2007, 12:08 PM
mbe301
mbe301's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow, way out of tune. No more bog, power is up... SWEET
mbe301 is offline
