RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Firehammer MT Dogbones Question
Reply
Old 07-10-2007, 09:45 PM
csp1971
csp1971's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Firehammer MT Dogbones Question
I have just snapped a second Firehammer MT dogbone. I just put a new dogbone in the outdrive coming off the differential and the end of the dogbone doesn't move very well. This was happening with the last one that snapped. I took a dremel to the inside of the outdrive to make sure there weren't any metal burrs. I did that before this dogbone and now with the new one it is rough again. Make sense? Has anyone else had this problem? The diff is smooth and there are no "catches" when it spins.
Thanks!
csp1971 is offline
Old 07-11-2007, 08:51 AM
kengentry5000
kengentry5000's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Firehammer MT Dogbones Question
My FH buggy dogbones have some play. If your bones don't have a little play in them they could be getting compressed with suspension travel causing the snap.
Is there a visible gap between the wheel-side drive cup and the wheel bearings? Maybe your wheel blocks are not in the right spot causing the outside drive cups to be spaced wrong on the inside of the wheel hubs.
Can you post some close up pictures of the outside drive cups where they make contact with the wheel bearings? Make sure the focus is sharp on the picture so we can spot any gap.
kengentry5000 is offline
Old 07-11-2007, 10:06 AM
csp1971
csp1971's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll post a couple pics tonight! Thanks!
csp1971 is offline
Old 07-11-2007, 10:17 AM
fgbasher
My Feedback: (10)
fgbasher's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
adjust the turnbuckle on the upper rear arms so they stick out a little further, this will give you some play with the dog bone.
fgbasher is offline
Old 07-11-2007, 09:06 PM
csp1971
csp1971's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Images attached. Let me know what you think. The outdrives were notched bigger when my diff housing blew about 6 weeks ago. This time, I'm not sure what the heck is going on.
csp1971 is offline
Old 07-12-2007, 12:38 PM
hellya
hellya's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i would swith your rear end to a FG alloy and add ball drives
hellya is offline
Old 07-12-2007, 02:27 PM
csp1971
csp1971's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have FG alloy housing on there now. For the ball drives that are out on HobbyThek's site, do you have to have the FG gears in order for it to work? I wouldn't think so since it is for the Comanche\Attack gears.
csp1971 is offline
Old 07-23-2007, 04:20 PM
hellya
hellya's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: csp1971
Yes.... you need the entire FG diff cause the spider gears are different in size...the ball drives wont work with the Clones diff
hellya is offline
Old 07-26-2007, 10:30 PM
csp1971
csp1971's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You must be talking about the FG Ball Drive set, not the Carson Ball Drive set. Carson makes two, one for the Comanche/Attack EVO and the other for the Attack. I believe these are direct replacements that will work with the current gears in the Clones.
csp1971 is offline
Old 07-26-2007, 10:35 PM
csp1971
csp1971's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh yeah, i snapped another dogbone tonight and lost the left outdrive. Now I'm just trying to decide what I should do. I have backup dogbones already in the mail from Tower. I just need an outdrive. That particular side snapped 3 dogbones. Maybe it was a blessing having it fly out. [sm=biggrin.gif]
csp1971 is offline
Old 07-26-2007, 11:41 PM
motors4fun
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When you assemble it back together again, check to see how much play is in there. I can move my dogbones around a small bit. if yours are tight then that is the culprit. Do like the post above says and spin the turnbuckles out a bit so you get the play you need in there. if it binds up at all thats not good.
motors4fun is offline
