mcd racerunner throttle mods
im looking for pics of mcd racerunner throttle mods as mine is catching on my airfilter cover so any pics would be appreciated
thanks
thanks
RE: mcd racerunner throttle mods
its definately doing something but i have been told that the best thing to do is make a new one out of the fg throttle linkage but was lookin for a few pics to have a look
So if someone tells you to use the FG linkage .. just make your own then , it will be alot cheaper and can even grab a few Thousands of a inch thicker rod to help with flexing also .. use aviation linkage at your LHS
Good Luck m8
Good Luck m8
Hi Whizzy,
I had some stiction problems with mine when I first set up mine, and it was because the slide on the throttle arm was not horizontal, so when freshly oiled it was fine, but within a few minutes of running it would start to stick.
My solution was to fit a spacer between the servo arm and the slider, no problems since.
What filter are you using, I've got the MCD one with a D&D pre filter, and whilst the linkage is close, it's never caught up.
I'll post a piccy later
hi iow basher in using n rn tuning filter with prefilter cover just rick at rossendale said he had to do a mod on his and has no problems with it sinceandd said he used the fg stuff to do it
hi iow basher i did the mod on sunday using the fg stuff works a treat and for a mere £5 each i think it was worth it although i already had the stuff here to do it and when the mcd one was removed i felt it sticking so hope that resolves the problem
