RC Giant Scale Cars For all those who love driving large scale rc cars share your projects or ask questions here.
Alloy engine mount stripped
Reply
Old 07-25-2007, 12:37 PM
csp1971
csp1971's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Alloy engine mount stripped
Okay, I have the large alloy engine mount on my Firehammer MT. The screw that goes through the rear bulkhead brace into the mount is stripped. I cannot find a longer screw to go into hole since it isn't that deep. I had it locktighted originally, but it would continue to loosen. Now, it just won't tighten. Should I use a larger screw? Is there any other way to repair this? These mounts cost enough money, I'm a bit disappointed that this has already gone bad.
csp1971 is offline
Old 07-25-2007, 12:40 PM
sb racing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Alloy engine mount stripped
You will need to re-tap the hole to m5 thread and use an m5 bolt instead of an m4.
I hope this helps.
Simon
sb racing is offline
Old 07-25-2007, 01:31 PM
hellya
hellya's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: sb racing
I hope this helps.
Simon
yep retap it to a larger bolt size
hellya is offline
Old 07-25-2007, 03:25 PM
csp1971
csp1971's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys, I'll give that a try!
csp
csp1971 is offline
Old 07-25-2007, 03:58 PM
kidd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
be careful with the drill those mounts are a soft cheap aluminum.
kidd is offline
Old 07-25-2007, 06:23 PM
slicrick
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just drill it out and use a m4 helicoil then you can still use the m4 screw
slicrick is offline
Old 07-25-2007, 07:43 PM
csp1971
csp1971's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tapped it with an M5. Worked perfect, thanks guys.
csp1971 is offline
