Installing FG Monster 2-Speed
Is there any good directions out there on installing the two speed. I have remove the orginal gears, but what do you do to get the drive shaft out?
VA
RE: Installing FG Monster 2-Speed
welp.. it could be a pain. you'll have loosen the allen screws in the brake disc sqaure so it moves freely. do the same for the layshaft gear.. If it all fails and dosent want to slide off.. cut the sucker in half! i'v had to do that way twice so far. You'll get a longer layshaft anyway.
If yours didnt come with instructions see if this helps. at the bottom on the right click there to enlarg the view
http://j.b5z.net/i/u/2162054/i/2_Spe...oad_Manual.jpg
